Hp 850 g7 `endpoint security controller ' error ....
  • bilen
    • Aug 2014
    • 637
    • istanbul
    hp 850 g7 bios password my device
    I disabled the password using rc unlocker
    but now i am getting this error :
    here is my original encrypted file :
  • volinakis
    • Jan 2021
    • 2859
    • N/A
    Re: 'Hp endpoint security controller ' error ....
    at 1st boot you have to enter bios setup - Security and restore security settings to factory defaults. put back original file, see if error goes away and then try again with unlocked file and restore security.
    • hardware1
      • Sep 2021
      • 2945
      • N/A
      Here's your Unlocked EC file, but I need your other chip to fix this End point problem. The chip could be 16MB or 32MB.
      all donations are welcome,
      • bilen
        • Aug 2014
        • 637
        • istanbul
        that didn't work
        • bilen
          • Aug 2014
          • 637
          • istanbul
          here it is
          • hardware1
            • Sep 2021
            • 2945
            • N/A
            here it is
            In the first boot go to bios menu and disable security options (Default).
            • bilen
              • Aug 2014
              • 637
              • istanbul
              it does not work
              • hardware1
                • Sep 2021
                • 2945
                • N/A
                it does not work
                what you mean by doesn't work? no image, no power or password still there?
                Program back your backup file and see if the device works or not.
                • volinakis
                  • Jan 2021
                  • 2859
                  • N/A
                  He has to program both chipsets with your files and after that power on laptop. if he programs one chipset and power on laptop it modifies the content of other chipset.
                  • bilen
                    • Aug 2014
                    • 637
                    • istanbul
                    the computer is working. but I keep getting the error on startup
                    • volinakis
                      • Jan 2021
                      • 2859
                      • N/A
                      program both chipsets with files provided by hardware1 and at 1st boot press F10 to enter bios setup, go to Security and at bottom you have restore security to factory defaults.
                      • bilen
                        • Aug 2014
                        • 637
                        • istanbul
                        I did exactly what you said, but the error does not go away
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          The TV does not turn on, the standby indicator is on. All voltages are present.
                          Emms is dead. Not readable, not detected.
                          Replaced emmc.
                          But with another dump there is no launch
                          Terminal log
                          UART
                          AC_ON
                          RPMB key is not yet programmed
                          HASH1_VERSION=0x00000000 64bit
                          E-B
                          FDE enabled
                          layout pattern onebin by SAR7,0...
                          06-01-2025, 02:11 AM
                        • sikocan
                          Lenovo X1 Carbon 9th Gen Black Screen
                          by sikocan
                          I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                          SN: PF3G1REP
                          MODEL: 20KW-00J1AU
                          PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                          Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                          06-24-2025, 09:01 PM
                        • lamonde
                          850 G6 Endpoint Security Controller Problem
                          by lamonde
                          Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                          and there is no soud after flashing new bios, may be have some solutions?
                          ProdID: 4YD62AV
                          SN: 2TK9500V8X...
                          01-15-2025, 09:31 AM
                        • Nene01
                          HP Elitebook 830 G8 HP Endpoint Controller error and no power issue (intermitent)
                          by Nene01
                          I have a HP Elitebook 830 G8 with endpoint controller error and besides that laptop sometimes doesn´t power on and i think it´s bios related also.
                          I already tried to solve the issue with SMDFlea patch fix and now i can´t power on the equipment anymore not even replacing main bios by its original.
                          Please take a look at my original main bios and help me if possible (i also attached EC BIOS without password).
                          The mainboard also had password that i manage to remove.
                          Best Regards...
                          01-11-2025, 01:09 PM
                          HP Clean VSS2 dumps,fix Endpoint Security error
                          by SMDFlea
                          Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                          the infamous **"Endpoint Security" error message.
                          Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                          I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                          The offsets and file sizes are part of the naming convention i`ve used for the extracted
                          files.
                          hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                          filling everything after...
                          08-08-2024, 03:14 PM
